Clearpass Insight Alert
i have setp an alert in insight that match cluster out of sync with 1 threhold and 1hr interval. i receive email every 30mins, it seems like it's not following the 1hr internal.
i have yet to test, but it seems like the interval is only applicable on the 1st send out, after that it will be every 30mins. which means that if i were to set the interval to 1min, it won't send out every min, it will send out 1 min when detected and there after is 30 mins. please correct if i am wrong.
is there anywhere that I can set the '30 mins'.
