Clearpass Integration with Ruckus
hi all,
My customer currently has a Ruckus wifi Infra and like to add Clearpass for below purpose. Anyone done it before ? Possible? Problems? My concern is the integration and will it work seamlessly. Great is someone has implemented or tested before.
  1. Customer want to use clearpass to authenticate/certify staff’s mobile devices before they can use the wifi network.
Clearpass require Wireless infra to have 802.1x and redirection features?
Thanks folks.
Re: Clearpass Integration with Ruckus
Yes, Ruckus use standards based authentication and should work fine.
Tim
Tim Cappalli | Aruba Security
Hello Tim. I am having trouble getting Aruba ClearPass to work with a Ruckus wireless infrastructure. The customer is a hotel that uses indoor Aruba APs for rooms and external APs from Ruckus on the social areas.
We have no problem with Aruba controller using a captive portal through CP guess feature.
Can you help us with this situation?
hbaez73
Hi Tim, this is the error we got when using Ruckus with clearpass, we are configuring custom vendor or Ruckus Wireless vendor and nothing look be better.
I have not seen that error before. Please open a TAC case.
Frequent Contributor II
Did you solved this error? I've got the same...
Thomas
ACMX#370 ACCX#1000
Hello guys,
to give you an update concerning the EjsErrors:
So apparently last year Ruckus changed some settings for their captive portal and they passed it on to  Aruba. Aruba did their changes on the clearpass, but as what they (Aruba) told me, they had to change it for all the Ruckus implementations.
Only Ruckus did this change for SmartZone and not for the ZoneDirector implementations, so ZoneDirector is working with the old captive portal implementation.
To solve this, go to your login form, in stead of chosing the Vendor Settings: Ruckus Wireless, choose the custom settings.
Your Submit URL has to be:  https://sip:9998/login
Username field: username
Password field: password
For the other settings you can use the default settings.
(For the Smartzone you can use de built in default Ruckus Wireless, and it will send his username and password to  https://sip:9998/SubscriberPortal/hotspotlogin)
(In this case we used ZoneDirector version 9.13.3.0 build 41 and Clearpass 6.6.7)
kind regards,
Thomas
ACMX#370 ACCX#1000
