Occasional Contributor I
Clearpass Integration with XenMobile 10.7
Love to know if Clearpass 6.7 can integrate a XenMobile 10.7 MDM.  I have read that Clearpass only supports the now deprecated SOAP API for XM; however, XenMobile is now recommending the REST API.  I wrote some python scripts to interact with the new REST API and it is working fine.  I cannot figure out how to get ClearPass to successfully poll it though.  Any thoughts?
BTW, we are cloud and not on-prem.
Wes
Re: Clearpass Integration with XenMobile 10.7
@dannyjump might be able to help.
Cheers
James
Contributor I
This is how I currently have it setup with 10.7
Thanks ccalhoun.  Are you on-prem or cloud?
Thanks, James.  Hopefully we can get @dannyjump to drop some knowledge on us.  I appreciate the quick response.  These forums are a great resource.
Wes
Contributor I
Tis is connecting to an onprem box. The documentation Citrix had was incorrect on the url path.
I would like to find this out to. Mine stopped working after we upgraded ClearPass to 6.6.9
