Clearpass Integration with XenMobile 10.x
has anyone tried to do the integration with XenMobile 10.x. The Soap API wich is default in Clearpass - external servers is depracted.
So you would have to do a Generic HTTP integration to a REST API with JSON. Has anyone done this yet? (So I can save a little bit of work ;-) )
Best, Johnny
Moderator
Re: Clearpass Integration with XenMobile 10.x
Joahnn,
We have a native integration with Citrix Xenmobile.... take a look at my MDM TechNote, find it here.....Tech Note: ClearPass Enterprise Mobility Management Integration V5
Best Regards
-d
Snr Tech Marketing Engineer - ClearPass
Hi Danny,
thank you for your reply. I know the native integration and the document. But it is now longer valid with XenMobile  versions > 10, because the interface was depracted. What remains is a Rest API.
See the attachments.
Best regards,
Johnny
Moderator
[ Edited ]
So I've just verified CPPM integration between CPPM 6.6.3 and Xenmobile 10.4. It took me a few days to get my environment back on online sorry for the delay.
Best Regards
-d
I have always tried to cennect on port 4443. Just reverted to 443. Now it works.
Thank you for your help!
Johnny
Can you provide the exact server url you are using to connect to the xenmobile server?  I am setting up CPPM 6.5.7 to Xenmobile 10.4 for the first time and I can't seem to pass the credentials correctly using the xenmobile context server setup dialog in cppm.
Hi, attached is a screenshot of those settings. I am using Clearpass 6.6.3.
Thanks!  The admin changed the instance name to zdmt instead of zdm so I edited the the url in your screenshot and I am able to poll now.  Thank you.
I am glad that you had success.
Please can you let us know permission required in XenMobile for account used in Clearpass?
