Cal
Clearpass OVF Deployment error with ESXi 5.5
Hi guys,
We are trying to deplot OVF into our ESXi for POC purposes, following the installation guide "Tech Note: Installing or Upgrading ClearPass 6.6 on a Virtual Machine".
When it comes to the Initializing Disk stage, it shows "EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)" and it's not processing further.
Anyone have experience with this before and how do we troubleshoot this?
Thanks.
Re: Clearpass OVF Deployment error with ESXi 5.5
Did you add the second Hard drive?
Thank You,
Troy
Have you tried leaving it and seeing what happens? Depending on the CPUs, RAM and disk speeds it may take up to 30 minutes for first boot.....
Cheers
James
Cheers
James
Cal
I'm worry due to the output lots different with what's showing in the installation guide, and not responding after waited for like 5mins.
Anyway, I leave it running for some times and it's up when I back from outside.
Thanks for the respond guys.
