MVP
Clearpass Onguard Auto-Remediation
Often people have questions on Clearpass Onguard like what firewalls and anti-virus softwares are supported? What P2P apps do we detect? etc. And which of these do we support auto-remediation for? For example, which firewalls can Onguard enable for the user automatically if the administrator has set a policy for it to be enabled. etc. This article will answer these questions.
For a complete list of supported third-party products and auto-remediation actions, go to the following page in your Clearpass server: Administration > Agents and Software Updates > OnGuard Settings. Next, click the Help link on the top right, and then click the OnGuard Agent Support Charts link.
Here are some screenshots:
The meanings of fields/columns in Support Charts and which of them is auto-remediation action is listed below:
Common Attributes
Attribute NameDescription
Product_NameProduct Name
VersionProduct Version
AntiVirus/AntiSpyware
Attribute NameDescriptionAuto-Remediation Action
GetDataFileTimeRetrieve the last modification time of the current definition/pattern file used by the Antivirus productNo
GetDataFileVersionRetrieve the current version of the definition/pattern file used by the Antivirus productNo
EngineVersionRetrieve the version of the Antivirus' scanning engineNo
Check RTPRetrieve the state of the Real-Time Protection (RTP) of the Antivirus productNo
LiveUpdateUpdate the Antivirus product (Dat File, Engine Version etc.)Yes
Sync/Async UpdateNot Used
SetRTPEnable/disable the Real-Time Protection (RTP) of the Antivirus productYes
LastScanTimeRetrieve the date and time of the last completed full system scan ran on the endpoint by the Antivirus productNo
FullSystemScanLaunch a full system scan for the Antivirus productYes
GetVirusDefServFull System Scan In ProgressNo
IsFullScanInProgCheck if the Antivirus product is currently running a full system scanNo
DiskEncryption
GetLocationsRetrieve list of encrypted locationsNo
GetEncStateRetrieve encryption state of location (drive)No
Firewall
IsEnabledRetrieve Firewall State (enabled/disabled)No
TurnOnEnable the FirewalYes
TurnOffDisable the FirewallYes
P2P
IsRunningRetrieve running state of P2P applicationNo
TerminateTerminate running P2P applicationYes
Patch Management
IsEnabledCheck if Patch agent is enabled or notNo
EnableSet Patch Agent to enabled stateYes
ListMissingDetect missing patchesNo
InstallMissingInstall Missing PatchesYes
Virtual Machine
EnumerateVMsEnumerate Virtual Machines on the systemNo
GetVMInformationGet extended information of a virtual machine (Name, Path, OS Version etc.)No
PauseVMPause the running Virtual MachineYes
StopVMStop the running Virtual MachineYes
GetHypervisorTypeRetrieve Hypervisor Type of Virtual MachineNo
Meaning of value fields:
V - Implemented
O - Not Supported
X - Not Implemented
Z - Implemented on Windows with Security Center (WMI) available
