I am trying to set up posture checks for wired clients on a 5412zl switch running 16.02 with Clearpass Onguard.
The process flow is as follows:
The user first connects to a production VLAN and if their device is healthy they are allowed access. If status is UNKNOWN they are bounced into a quarantine VLAN where they are redirected to the Onguard portal and no internal network access is allowed.
If they run the dissolvable agent and fail the checks I want to be able to allow them to self-remediate via some http links posted to that Onguard page (windows or AV updates etc).
Now, I understand with a controller scenario, it is possible to embed Windows/Antivirus update urls on the Onguard page and use portal free-rules and portal user-url configuration on the controller to allow them to access the links via the Internet. Is this same feature possible on the Aruba Switch OS? All I can see is ACLs using specific IP addresses or ports but not URLs, but ideally would like to be able to point them to a specific URL say Microsoft or an Antivirus website.
Elvis.
