Clearpass Policy Manager with external MS SQL DB for Guests
I’m new the Aruba world have a problem with the authentication methods fort the guest users.
We setup a new cp server with iap controller in our environment.  I configured the ipa with the cp for the guests at first with the local cp database, everything works J
But I want to import my guest’s ids from the access system database where everybody had to check in. so I configured the external sql db source. In this database I have a table with the guest id and code from the chip card. I want to use these two fields for my guest login.
The problem is when use pap (clear) as methods for authentication I get this error:
PAP: CLEAR TEXT password check failed
When I change pap to md5 and convert the password field in the sql table I get this:
Cannot select appropriate authentication method
Whats wrong in my configuration?
thanks
daniel
Re: Clearpass Policy Manager with external MS SQL DB for Guests
Can you paste the SQL query he is using to retrieve the password from the DB and also  may i know if  password is stored in cleartext in the DB ?
thank you.
hi,
this is the query i use.
select Password from dbo.GuestUser where User = '%{Authentication:Username}'
in the password field the md5 hash is stored.
Contributor II
hi,
am trying to do same urs configuration,
i want ti integrate clearpass with external sql server,
could you please show me how did u configure sql query and the alias name on your clearpass??
thank you
MVP
@sriram.subramanian do you have an answer for this question?
Sean Rynearson
hi sir
i have also same issue when integration with the MS SQL DB, can you show me how you do it, i also encounter same error as you mention in your 1st post.
any one can help.
can you share configuration sir? i have also same case but failed,
