Clearpass Port number for Ipsec tunnel
Hi... can anyone tell me which port numbers needs to open in Firewall to reach clearpass? we were using IPSEC tunnel from remote to HQ to reach clearpass.. IAP's has been deployed in branches...
Re: Clearpass Port number for Ipsec tunnel
It should be UDP 4500 for IPSEC.
A list of other ports are here:  https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/Ports-needed-by-CPPM-if-a-firewall-is-within-wired-infrastructure
Thanks... will try and update you
