Clearpass Ports required in multi controller enviroment
Hello
If i got a  multicontroller enviroment
I got 2 Controllers Master and stand by
5 more local controllers
I got a vlan that just exist inthe controller
I configured the Captive portal profile on the master controller i redirect it to the CLEARPASS
Do i need to open the ports just between the Clearpass and Master/Stand by controller?
I dont need to open ports between local controllers and clearpass even if the aps that the clients are connected are on the APS terminated on the local controller?
I belaive i have to open this
Between Master and Stand by controller
RFC 3576 - UDP port 3799
RADIUS - UDP port 1812
RADIUS Accounting Server - UDP port 1813
HTTP : TCP port 80
HTTPS: TCP port 443
Question here(this ports should be bidirectionals???
Also the Clients in vlan 999 that just exist in the controller should have access to clearpass trhoguh the port 80 and 443 so they have access to the clearpass portal.
cheers
Carlos
Alternetworks Corp
Re: Clearpass Ports required in multi controller enviroment
anyone?
Alternetworks Corp
Any controllers that could have APs on them need to have ports opened between them and clearpass..
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
thank you Collin
The ports needs to be open bidirectionally???
Cheers
Carlos
Alternetworks Corp
