Clearpass Profiler for wired devices and report
Hi all,
I am trying to use Clearpass Profiler to profile wired endpoints (Windows 7,8,10 machines) connected to a switch. I have applied the necessary configuration in the Profiler configuration (SNMP, SSH, WMI, subnets, etc). I have then run the Network Discovery and have discovered the devices. I would now like to create a report that shows the endpoint to switch and switchport mapping but can't seem to find the report in Insight. Does anybody know how else I might be able to pull this information?
Re: Clearpass Profiler for wired devices and report
Try add columes NadIP and NadPort if that helps. If that does not addresses your requirment , file feature request at Aruba support site.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
