Clearpass RADIUS PAP with DUO MFA
Hi, does Clearpass integrates with DUO MFA for VPN autentication?
DUO MFA allow RADIUS concat, so can Clearpass define DUO as its source and also do not use DUO RADIUS proxy server, but instead of it use Clearpass (see Network_diagram pic.)?
Maybe there is an examples or documentation?
Re: Clearpass RADIUS PAP with DUO MFA
Yes, but ClearPass would point to the Duo auth proxy.
Tim Cappalli | Aruba Security
Do you have any example documentation?
Add a token server authentication source pointed to Duo. That's all there is to it.
