Contributor I
Clearpass Registration and Login Screens keep looping around
when registering on Clearpass as a guest I have a problem. Guest enters their details on the registration screen, they then get sent to the login screen but when they click "Login" they get sent back to the reg page and are unable to go anywhere else. Can someone please help?
Re: Clearpass Registration and Login Screens keep looping around
What infrastructure are you working with?  Aruba, Aruba Instant, wired???
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Contributor I
Aruba, controller is a 3400
Did this ever work?  Do all clients behave the same way?
In the captive portal profile, is the server group set to Clearpass?  Do you see anything in Access tracker?
Seth R. Fiermonti
Email: seth@hpe.com
Contributor I
Yes it has been working. I just changed the login page earlier but changed it back and now it won't work.
Where do i find access tracker?
Contributor I
I found it, looks like an authentication error
Error Code:
204
Error Category:
Authentication failure
Error Message:
Failed to classify request to service
 Alerts for this Request
RADIUSService Categorization failed
Sounds like something else perhaps changed here...
So...this means that Clearpass saw the request from the controller but didn't have anywhere to categorize it into services.  Did you set up this Clearpass server?  If you look (where you found Access Tracker), under configuration and services, there should be one marked Guest, in there, there is a service categorization.  Please ensure that the ssid entered there matches the ssid you are using off the 3400.  Post a screen shot of the service if you can.
Seth R. Fiermonti
Email: seth@hpe.com
Contributor I
No it was set up by an external company. I've checked and the SSID was incorrect, it is now working.
Many thanks for your help.
Awesome...glad it was a quick fix :smileyhappy:
Seth R. Fiermonti
Email: seth@hpe.com
Contributor I
Me too! :smileyhappy:
Thanks again!
