Ciao,
a customerr's SMS provider works with a POST using part of it encoded.
Let me give an example of the POST:
<?xml version="1.0" encoding="utf-8"?>
<soap12:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap12="http://www.w3.org/2003/05/soap-envelope">
<soap12:Body>
<SendSMS xmlns="http://tempuri.org/">
<sUtente>username</sUtente>
<sPassword>password</sPassword>
<vByte>
!!! """The following part need to be encode with Encoding.UTF8.GetBytes(someString);"""
<XML>
<TESTO>@MESSAGE@</TESTO>
<CONTATTI>
<NUMEROTELEFONO>@TO@</NUMEROTELEFONO>
</CONTATTI>
</XML>
!!! end of encoding
</vByte>
<sCompany>Company_name</sCompany>
</SendSMS>
</soap12:Body>
</soap12:Envelope>
Do you think could be possible to implement using ClearPass?
