Clearpass Serial #
I have a CP-500-HW in a remote data center.  Is there a way to pull the serial number of the device through the CLI or web gui?
Thanks in advance!
Dan R.
Network Engineer
ACMA
Aruba
Re: Clearpass Serial #
Hi Dan,
Try clicking the link in the attachment.
There is a field for serial number... the example is blank (as it's a Virtual Appliance) let's see if yours will report and save you a roadtrip ;)
JF
That worked.  Thanks a ton!
Dan R.
Network Engineer
ACMA
Aruba
Anytime Dan.
JF
Frequent Contributor I
This just saved me. Thanks for the tip! Screenshot was excellent.
i did what you said with your screenshoot but i just found "none", maybe its because my clearpass is on a virtual machine. how can i find the serial? i really need that information because i want to open a case. please help me with this.
thanks.
How to check if it is showing none as Serial number like in Example
If it is a virtual instance then use the subscription #
Thank you
Victor Fabian
Lead Mobility Architect @WEI
