Clearpass TACACS - Authentication fail
Hi Guys,
I'm using the CPPM as a TCACS Server, authenticanting some different switches models .
I'm having a problem specifically with an HP (H3C) switch. When I try to access this switch with username and password that is registered in CPPM internal base, I receive the information from CPPM that the autehntication was accepted, but the switch reject the access.
I have no problem with the others switches ( Ciscco and Dell).
Is there something that I need to configure in the CPPM specically for HP (H3C) switches?
Thanks i advance.
Leandro Surcin
Re: Clearpass TACACS - Authentication fail
Youneed to send back a privilege level of 15. Create a new enforcement profile and add it to your policy.
Tim Cappalli | Aruba Security
HP ProCurve config:
aaa authentication login privilege-mode
aaa authentication ssh login tacacs local
aaa authentication ssh enable tacacs local
tacacs-server host 10.100.60.80 key Pr0Curve
ClearPass:
Enforcement profile:
Enforcement policy:
Hi.
Its an HP 5120 switch model from H3C and I already configured the enforcement profile privilege level 15.
Do you have some other advice?
Tks.
Super Contributor I
Have you set super password?
[CS01]super password level 3 cipher ?
  STRING<1-53>  Ciphertext password string
[CS01]super password level 3 cipher yoursecretkey
 then after you authenticate at level 0, type "super" to get to level 3
<CS01>super
Please input the password to change the privilege level. Press CTRL_C to abort.
 Password:
User privilege level is 3, and only those commands can be used
whose level is equal or less than this.
Privilege note: 0-VISIT, 1-MONITOR, 2-SYSTEM, 3-MANAGE
~Trinh Nguyen~
Boys Town
Hi.
Tks.
Did you ever get to the bottom of this?
