Contributor I
Clearpass: Using custom attributes in profiles
Hi all,
i'm trying to use custom attributes, i have created for the entity "EndPoint" via "Administration>Dictionaries>Attributes". I want to use those attributes in profiles with CLI enforcments... a example would be, configuring a description via CLI enforcment for a switch port by extracting the defined custom attribut.
My question is, how to use an attribute named "My Description" in the profiels? i have tried %{Endpoint:My Description} with no success. No alert in Access Tracker and Application Response only shows "CLI:TargetDevice" but no commands.
Any ideas or hints?
Best Regrads
Re: Clearpass: Using custom attributes in profiles
That is the correct syntax. Do you have the Endpoints Repository as an
authorization source?
Tim Cappalli | Aruba Security
Contributor I
Thank you @cappalli. Yes it was included - i think i have found my problem:
I configured the attribute with a default value in the attribute settings. If i updating the endpoints custom attributes, setting them to something other than default or just simply saving it, it seems to work?
MVP
I didn't even know this was possible. So cool!
Thanks for sharing.
Cheers
