Frequent Contributor I
Clearpass and Cisco IOS
is that all the version of IOS cisco is compatible with Clearpass ?
Where i can find a documentation about DACL Cisco compatible with RADIUS Clearpass ?
Regards
Yann
Aruba
Re: Clearpass and Cisco IOS
Are you looking for something specific?   Is something not working?
Please reference the CPPM and Cisco Switch Technote for details: http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=10344
Also Attached.
AMFX | ACCX | ACDX | ACMX
Contributor II
you've got to test this very, very carefully. cisco implementation of 802.1x is patchy. make sure you test all your wired scenarios
