Clearpass and HP Procurve switches integration for 802.1x and wired guest
We are deploying clearpass in our network and having below requirement
We have HPE Procurve 5300,2700 switches and want to integrate with clerpass for 802.1x authentecation with policy condition to check for Corp device and if end device is not part of domain then device should get guest captive portal.
I didn't find any useful resource on internet also I heard that there are issue with COA too. Please help me to integrate the same.
Re: Clearpass and HP Procurve switches integration for 802.1x and wired guest
Please provide the exact model and code versions.
Tim Cappalli | Aruba Security
Hi Cappalli,
Thanks for immediate response.
HP Procurve 5304xl and 2724(15.16.0011) software code.
Also please let me know which software code and HP Procurve switch model support it as i have other series of Procurve switches too.
Those are very old switches. We have only tested ProVision and newer switches. I would reach out to your ClearPass partner.
Will 802.1x working on those switches ?
I would assume so just because 802.1X is usually pretty standard, but honestly, I’ve never even heard of these models before.
It's 2700 and 5300 series switches. Can you give me procurve switch and software code list which fulfill my requirement.
