last person joined: 9 hours ago
Clearpass and OpenLDAP
  • 1.  Clearpass and OpenLDAP
    Posted Apr 29, 2018 08:33 PM
    Hi all.
    I'm trying to autenticate users using ClearPass and OpenLDAP. The autentication mode is EAP TTLS + PAP.
    It works fine when the user password hash is cleartext, but if we change to SHA1 or other methods we got the follow authentication error:
    (RADIUS PAP: Configured SHA1 password has incorrect length)
    This link says the EAP TTLS + PAP supports all methods.
    http://deployingradius.com/documents/protocols/compatibility.html
    Do you have any tip?
    Thank you
  • 2.  RE: Clearpass and OpenLDAP
    Posted Apr 30, 2018 09:38 AM
    You need to convert the clear text password to sha format
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Clearpass and OpenLDAP
    Posted May 02, 2018 12:24 PM
    Hi Victor.
    All users' passwords are in SHA1. We have created a new user with cleartext password for testing.
    The user with password cleartext authentication works, but not for users with password in SHA1 mode or another method.
  • 4.  RE: Clearpass and OpenLDAP
    Posted May 02, 2018 12:28 PM
    The SHA-1 hash is prefixed with {SHA} in the userPassword attribute?
  • 5.  RE: Clearpass and OpenLDAP
    Posted May 09, 2018 09:59 AM
    I'm sorry for delay.
    Yes. It is prefixed with {SHA} in the userPassword attribute.
    Any other idea ?
    Please see the pictures attached.
  • 6.  RE: Clearpass and OpenLDAP
    Posted May 09, 2018 10:28 AM
    That error generally means the password is not stored correctly.
  • 7.  RE: Clearpass and OpenLDAP
    Posted May 09, 2018 03:07 PM
    Thank you Tim
    I checked the option 'Bind User - Allow bind using user password ' at clearpass side, and it worked with SHA1.
