Contributor I
Clearpass and accounting
Hey
Currently trying to learn Clearpass. Setting up CP as radius for our 7220 controllers.
When starting to setting up guest portal I noticed that after enabling accounting to get correct licensing going on the radius server, all users are listed under "Active Sessions" in the guest portal.
I thougt maybe the the users was getting the guest role in the controller, but all users with "authenticated" role is also listed under active sessions. Can anyone help me in the right direction ?
Thanx
Regards
Jon
Re: Clearpass and accounting
This is normal. All active network sessions are shown there.
Tim Cappalli | Aruba Security
Contributor I
Ok, I thought maybe only guest users was shown in the guest list.
Regards
Jon
