Clearpass as TACACS for Cisco WLC
I have configured Clearpass as TACACS for a Cisco WLC.  I have verified I'm hitting the correct profile.
Under that profile I am using the CiscoWLC:Common service to provide the name role1 with value of ALL.  The cisco is not liking the message its getting from clearpass and is classifying it as a Authentication failure.  Is there anything else I need to add or change?
profile attached.
Re: Clearpass as TACACS for Cisco WLC
There is no profile attached.
If its an auth error it usually isnt a profile issue. Can you attach the alert in access tracker
Thank You,
Troy
It actually shows it passes in Clearpass.  The WLC just isnt likeing the response for some reason.
Attaching images:
Even though it passes Auth sometimes there is still an alert in access tracker. I ran into the same thing yesterday with a juniper switch. I just wanted to make sure.
Thank You,
Troy
I am experiencing this issue trying to get my WLC to work with Clearpass for tacacs admin.
Any ideas?
Have you tested with the Privilege level = 15 in the enforcement profile?
I am having this issue too.  Yes I am using priv 15 as well.  session detail states:  ciscowlc:  Fail.    Auth Request Message on Alert tab:  Tacacs server=ciscowlc:common not enabled.
I found/fixed my problem. It was a config issue in my policy.
 Hi Berg,
Can you please share on what was the issue on the policy? i am having the same problem too.
Regards
Aabarnam S
I had to add priv 15 to my enforcement.
