Clearpass between two sites with vpn site to site connection
Hi Community:
Anybody knows if it's possible to configure the Clearpass when I have a vpn connection between the sites.
e.g:
I have the CPPM instaled  at main office, so in the branch I want to autenticate the guest users with the CPPM.
The question is: How can I do it ?
The vpn connection is between Cisco Meraki.
The access points are IAP-315 (instant solution)
Thanks in advance.
Regards
Re: Clearpass between two sites with vpn site to site connection
Yes. As long as the IAP VC can reach ClearPass, then you can authenticate users.
Tim Cappalli | Aruba Security
Thanks for your help.
Yes, VC can reach Clearpass. I can ping from VC to Clearpass.
At main Office is working fine, but when I try to connect to guest SSID the portal isn't working.
So, What else I need to configure?
the dhcp server is provide it by the cisco meraki at branch.
Did you configure all of the required captive portal options on the IAP?
Yes. all field required.
