Occasional Contributor I
Clearpass blacklisted users
I applying an enforcement profiles that blacklist any user when daily bandwidth limit is exceeded.
The Clearpass is configure to purge all blacklisted users at midnight
Everything working fine
How do I exclude the implementation of this enforcement profile on a specific users and keep it applied on all other users?
Best Regards
Re: Clearpass blacklisted users
What type of authentication are you using ?
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
AD  &  MAC
Best Regards
If is based on a certain type of user can you can leverage AD memberships to determine who or not will be blacklisted
Get Outlook for iOS
Thank you
Victor Fabian
Dear Victor
You mean that we can created an enforcement Policies for a specific AD-Group members ?
Best Regards
Yes
Get Outlook for iOS
Thank you
Victor Fabian
Dear Victor
thanyou ...its working
but how can manually synchronize Active Directory users with the Clear-Path
Best Regards
What are you trying to synchronize? Please clarify.
Tim Cappalli | Aruba Security
Dears
I create AD Group ( wireless_No_blacklist )  and i create an enforcement condition to give allow access to ( Wireless_No_blacklist ) members
check out the attached Pic.
the problem is: when i assign a new AD user to (Wireless_No_blacklist ) it takes many hours to appear on clears Pass so is there any way to sync the new users manually
Best Regards
You can either do a clear cache manually under sources > your ad
Or decrease the cache value
Noté: be careful decreasing the value because that means that clearpass will contact the AD more often
Get Outlook for iOS
Thank you
Victor Fabian
