last person joined: 10 hours ago
Clearpass captive portal Keep Redirecting after Self registration?
This thread has been viewed 21 times
  • 1.  Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 18, 2014 07:20 PM
    I have enabled self registration and after adding all self registeration fields and accepted it keep redirect to teh same register page not go to internet..is there is some thing I'm missing?
  • 2.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 18, 2014 07:21 PM
    Is access tracker showing a successful web authentication?
    What is your default guest role in the AAA profile?
  • 3.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 18, 2014 07:32 PM
    Guest-Logon
    as you can see in teh attachemnt after the self register finish or account enter the username and pass word it gives this and when you type any page it get me back to the login page
  • 4.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 18, 2014 07:34 PM
    Your default guest role should be the final guest role, not the logon role.
  • 5.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 18, 2014 07:40 PM
    Check the AAA as attached adn aslo access tracker shows no thing
  • 6.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 18, 2014 08:18 PM
    @wireless Guy wrote:
    ..... adn aslo access tracker shows no thing
    If Access Tracker does not show anything for your logon, check to see if your Captive Portal profile has a server group defined that contains your CPPM server (below).  Also check to see if the controller setup as a Device (RADIUS Client) in ClearPass.  If it is not, you'll see an warning message in the CPPM Event Log (Monitoring --> Event Log).
    Also, review the attached document; it outlines the ArubaOS and CPPM integration at a high level.
    Attachment(s)
  • 7.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 18, 2014 08:19 PM
    My mistake. Set the default guest role in the captive portal profile under L3 authentication.
  • 8.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 18, 2014 11:13 PM
    My mistake. Change the guest role in your captive portal profile.
  • 9.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 18, 2014 11:57 PM
    @Wireless Guy In your screen shot you also have Downloadable role from CPPM enable. Are you sending just a role or a downloadable?
  • 10.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 19, 2014 12:34 AM
  • 11.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 19, 2014 12:39 AM
    Thank you so much airheads team i will try it and feed you back I really thank you all :)
  • 12.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 19, 2014 12:41 AM
    Dears should I contacts support to issue clearpass application license as I have one of my customer that we want to issue a license for him as he purchased gust and on guard
  • 13.  RE: Clearpass captive portal Keep Redirecting after Self registration?
    Posted Nov 18, 2014 07:48 PM
    Can you please tell me the right sequance to create only a Guest Service on Clearpass and AAA in the controller the rest I can do please help
