Clearpass cisco wired dot1x with dacl
Hello all,
Am trying to wired dot1x clearpass with cisco c2960 switch ios 15.0 version,
Am able to auhenticate the client but no dacl its seen on access tracker, and am using default template of dacl( permit tcp any any)
Second thing am trying to apply coa ( cisck terminate session)
And its not applied, even when am trying manually getting failed to apply on client mac address,
Nad devic setting for cisco with port 3799 which same on cppm also,
If its not support on switch can we use onconnect?
Any suggeestion
Thank you
Re: Clearpass cisco wired dot1x with dacl
Did you follow the ClearPass Solution Guide for Wired Policy Enforcement?
Tim Cappalli | Aruba Security
Yes i check it, and i have applied it on another cisco switches with different customer and it was wroking fine,
Do i need to add vlan enforcment with dacl to make it work?
Is there any tshoot document for dacl and coa?
Please double check the configuration. Something isn’t configured correctly.
