rzz
Contributor II
Clearpass credential caching for DC deployment
Hi All,
Would like to check if clearpass is deployed in a DC and wireless access points are deployed remotely in differnet countries, if upon WAN link failure and with credential caching set, will users be required validation back to the clearpass before connectivity is granted?
This is to see if there will be any network impact on user wireless connectivity if CPPM is unreachable.
Have checked against http://community.arubanetworks.com/t5/Security/CPPM-Authentication-Source-Cache-Timeout/td-p/200443 am not able to get a clear answer.
Re: Clearpass credential caching for DC deployment
The network device would need to be capable of authentication survivability.
ClearPass does not cache credentials.
Tim Cappalli | Aruba Security
