Occasional Contributor I
Clearpass enforcement profil for changing port to Trunk and change Native vlan Cisco switch
Having problem with Clearpass.
I can get clearpass to change the port to a trunk, but the native vlan is the access vlan thats configured on the cisco switch, i need to change that, any idea?
The Vlan the port is on is 45 and need to change the port to trunk and native vlan 10.
tried with a standard vlan enforcement but that just override the trunk configuration.
Thx.
Morten
Re: Clearpass enforcement profil for changing port to Trunk and change Native vlan Cisco switch
I have not done this myself but looked into it some time ago. Here are the pointers that I collected on this topic.
It's not a need to have, just a nice, i can see in the tread, that it's not recommend to do authentication on a aruba ap, and i'm not gonna do macro on ports.
But ill contact or Aruba partner.
