last person joined: 11 hours ago
Clearpass guest integration with non aruba wireless
  • 1.  Clearpass guest integration with non aruba wireless
    Posted Sep 21, 2015 11:51 AM
    Just wondering
    The minimum requirement for this is that it support radius?
    If the 3rd party wifi equipment does not support radius then it cannot be integrated with clearpass guest?
    Or its possible to do something like the nomadix in which you dont need anything as requirement as it acts as a internet access gateway in which you dont need any configuration in the WIFI side.
    Cheers
    Carlos
  • 2.  RE: Clearpass guest integration with non aruba wireless
    Posted Sep 21, 2015 11:53 AM
    At a bare minimum, the device needs to support RADIUS. I'd be shocked if
    there were wireless solutions that don't support it. Even most consumer gear
    supports RADIUS authentication.
    Depending on the solution, it should also support RADIUS Change of
    Authorization.
  • 3.  RE: Clearpass guest integration with non aruba wireless
    Posted Sep 21, 2015 12:03 PM
    Well you can be shocked becase this thing doesnt support radius...
    The thing is that its a  intelligent multiservice gateway of allied telesys ( IMG)
    The thing is that it does many thing and it has Wifi incorporated... is not really a WLAN solution or something like that... its like something else that HAS wifi.
    For example its like a ADSL that has a wifi antenna but that is not a wireless solution. i dont see if you get my point?
    i was looking onthe config but i didnt see any radius tab... also i downloaded the manual, and i did search for radius and i got no result....
    Thanks for the info
    Cheers
    Carlos
  • 4.  RE: Clearpass guest integration with non aruba wireless
    Posted Sep 21, 2015 12:33 PM
    In those cases you can put an arubu contoller inline to act as a wired concentrator like a Nomadix box. I've done it at a few customers where some of the old equipment wouldn't support captive ports redirect.
  • 5.  RE: Clearpass guest integration with non aruba wireless
    Posted Sep 21, 2015 12:40 PM
    I though in that, but they would need to buy a 7210 controller at least for it
    They wanted it to work with their wifi solution alone
    We will need to explain them that the only solution would be with a controller.
    Cheers
    Carlos
    #7210
  • 6.  RE: Clearpass guest integration with non aruba wireless
    Posted Sep 21, 2015 12:42 PM
    How many users does the system support? You could likely get away with a
    smaller controller to handle this functionality.
