Frequent Contributor I
Clearpass in HA mode
Have one virtual appliance (v6.4.2) in production and running for quite some time.  Just purchased another to act as a hot standby.  Is there a simple way to proceed?
Re: Clearpass in HA mode
Join it to the cluster and then add it to your network devices as a radius server.
Then you can setup the virtual IP for guest access.
Tim
Tim Cappalli | Aruba Security
What are your goals for HA?  Is it just for redundancy or to load balance RADIUS requests?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
just redundancy
Great...then you should be able to add the second node as a subscriber and then create a VIP between them.
Seth R. Fiermonti
Email: seth@hpe.com
If your controllers are on 6.4, I would highly recommend enabling radius load balancing.
Tim
