Clearpass integration with aruba introspect
Can anyone provide configuration documents for integrating Aruba Introspect UEBA with Clearpass?
Atleast, suggest the logic/tips on integration if no documentation available.
Re: Clearpass integration with aruba introspect
A public document has not yet been released.
Tim Cappalli | Aruba Security
Please work with your local Aruba IntroSpect SE to understand the use-case and get you started or the documents.
Do you have an IntroSpect AN setup? I can help you with the config if you have an immediate requirement. The TechNote is Work In Progress and should be available soon.
The logic is simple
1. ClearPass posts user/device context to IntroSpect using Endpoint Context server actions leveraging the APIs on IntroSpect.
2. IntroSpect can Quarantine a risky user on the network leveraging the APIs on the ClearPass
