Clearpass integration with ubiquiti
Has anyone by any chance, integrated clearpass guest with ubiquiti??
Alternetworks Corp
Re: Clearpass integration with ubiquiti
What specific features are you looking at?
Tim Cappalli | Aruba Security
captive portal with clearpass guest that allows you to integrate it with opera.
They wish to change the nomadix to clearpass.
Alternetworks Corp
im also stuck onthe ubiquiti side The controller offers RADIUS only under WPA-Enterprise condition. We have set "External Portal Server" to point to the relevant registration page on the ClearPass (i dont see something to  redirect to any subdirectories, just to one IP).
Alternetworks Corp
Can you give me a week? I have a UniFI AP on the way.
yeah if you can give us if its possible it would be great!!
There are many clients in our country that use unifi, and got nomadix
They are not happy with nomadix and if we can make ubiquiti works with clearpass, we would be able to get in those accoutns with clearpass!
Thanks Tim!!
Cheers
Carlos
Alternetworks Corp
Hey Carlos - I played with this a bit last night and I don't think it's something we can get working right now. They don't use a traditional client browser POST and they also do not support CoA. Please submit a feature request for this.
Something else I noticed was that they don't support MAC-Authentication, so if we were to get the captive portal authentication to work, the user would have to re-authenticate everytime they disconnect and reconnect.
Thankss for your time Tim
Cheers
Carlos
Alternetworks Corp
