Frequent Contributor II
Clearpass latest patch causing problems...
We just got Clearpass up and running in a wireless sandbox for testing and tweaking. We had the basics up and running with 802.1x with WPA AES. Then comes along the patch yesterday (Cumlative Patch 2 for 6.3.0, 6.3.1) and now its broken :smileyfrustrated: as noone can now authenticate. Here is the error I keep seeing in the Access Tracker:
Any advice from anyone?
Scott McNeil - Sr. Network & Security Engineer, Global Process Automation
Network+ | CWNA | CWTS | ACSP | ACMP | ACMA | BREC
Re: Clearpass latest patch causing problems...
You need to add ClearPass to the domain
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks Victor,
One of AD server guys checked it out and you were correct, somehow it was no longer joined to the domain. Once I re-joined the domain it started working again. Much appreciated!
