Clearpass multi-AD, how to join to multiple AD if single DNS cannot resolve all domains?
Hi, I'm setting up CP to authenticate endpoints on 3 separate, non-connected networks. The networks are connected to CP on individual VLAN interfaces. I've setup route statements to direct traffic to the proper VLAN based on the IP subnet.
How can I join CP to multiple ADs if the DNS server can only service requests for one of the ADs? I can't use conditional forwards in DNS because the ADs can communicate with each other.
Re: Clearpass multi-AD, how to join to multiple AD via different interfaces? Multi DNS?
I know you can add up to 3 DNS servers, but I'm assuming that this is simply a failover scenario, when a server becomes unresponsive, it will hop to the next...
Is it possible to assign a DNS server for each domain?
If your main domain controller cannot resolve all Active Directory domains in your environment you may need to stand up a split-DNS server for ClearPass with conditional forwarders.
Tim Cappalli | Aruba Security
