Clearpass onconnect is not adding switch ports upon clicking add port names
1.Configured SNMP v2 on cisco catalyst 3560 switch.
2.Edited the default zone in Administration Agents and Software Updates > OnGuard Settings and saved.
3. In the Clearpass Device I have added cisco switch with SNMP Read and write settings.
4. when i go to the onconnect enforcement tab, and click on querry ports It is showing the list of ports.
5. Now when i select the port and click on "add to port names" button, It is not adding ports on Port names (CSV)
Can comeone suggest what has to be done apart from what i have done.?
Note: customer informed that they can not configure zones in his switch as his switch doesnot support zones. (and so I decided to go with default zone instead of adding a new zone by a new name)
Re: Clearpass onconnect is not adding switch ports upon clicking add port names
Your first screenshot is for OnGuard which is not currently supported with OnConnect.
Did you follow the Wired Policy Enforcement solution guide step by step to se this up?
Tim Cappalli | Aruba Security
