Clearpass policy manager maximum devices?
Hi all,
I have a question about the devices that Clearpass CP-500 can manage?
I have CP-500 and Aruba recommend CP-500 manage maximum 500 devices.
How CP-500 calculate the devices? If devices 501 - 600 that connects to network, CP-500 will drop or reject or devices still be authenticated and connect to network?
Thank you for you support.
Khang Vo
Re: Clearpass policy manager maximum devices?
Clearpass will never reject an auth because of lic violation. If you violate lic 4 out of a 6 month period then the admin will be locked out until they call TAC and have it unlocked
Thank You,
Troy
