Regular Contributor I
Clearpass problems with guest login after https certificate change
Hi@all,
we have an other strange problem with our clearpass, we uploaded a https certificate to our clearpass, wie changed the ip to the hostname guest.domain.de in the IAP captive portal profile. Now we changed in the cp guest capitve portal the securelogin.arubanetworks.com to guest.domain.de.
Now when we login to the captive portal with username and password, the captive portal redirects us to the clearpass admin login page and we havent entries in the access tracker with the guests username.
mac auth works fine, and we have entries in the access tracker but new guests with username and password cannot login.
have anyone an idea for this strange behavior?
Re: Clearpass problems with guest login after https certificate change
Change that back.
Cheers
James
yes, we tried it but the web browser says site not found... Can this be a problem with the instant https certificate?
How can I resore the original Instant https certificate?
What's the name on your Instant HTTPS certificate?
Cheers
James
instant.domain.local
Change the highlighted on your guest page to instant.domain.local
Cheers
James
can I use the VC IP-Adress instead?
No, as you're using HTTPS.
It needs to be the subject name on your Instants HTTPS certificate which you have said is instant.domain.local.
Cheers
James
Make sure you're using a publicly signed certificate.
Tim Cappalli | Aruba Security
