Clearpass routing
Im using data and managment interface
I need to get the updates from managment interface
I though it used the managment interface for the update but it doesnt...
I see that i can configure a route for that but i guess it just accept ips.. but not domains...
i need to get updates from
i guessi could put the ip that resolve but if it changes it wont get any updates....
Any help
Or the only way is using the data port?
Alternetworks Corp
Re: Clearpass routing
You will need to create a management route to pull updates over the management interface, as the default route will go out of the data port (when enabled).
Check the ClearPass Services Routing Technote for the details:
 .. and yes that route is for IP only. The IP for seems pretty stable though.
So its not possible to add the domain as the destination?.
So my optios are
1 use the ip as destination but knowing it can change if i want to use the managment port
2 use the data port for this uodates
Therw is no other option
Alternetworks Corp
