Clearpass terniate wireless after cert installed issue
Hi All,
I have a questions on clearpass for you.
I am doing configuration for onboarding now, and my device can successfully onboard to the network, just one more step further, i would like to know if there's any way to disconnect wireless for client after certifacate has been installed successfully? This will not require user manually to disconnect and connect back to network again.
I tried set the cisco termination session, but looks like it doesn't work.
Shawn
Re: Clearpass terniate wireless after cert installed issue
You shouldn't need to do anything special in the enforcement profiles...this is handled by the OnBoard configuration.  There is a setting under Network to automatically reconnect the client.  Once Onboarded, the client will issue the reconnect.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
But you must enable COA on network device
Thank You,
Troy
Correct...I thought that was already done.  Probably a poor assumption on my part!
Seth R. Fiermonti
Email: seth@hpe.com
