Clearpass upgrade 6.4 to 6.6 In virtual appliance
I would like to know the steps for this upgrade.
I see that on the release note  you need  as a requirement 1 TB of HD
Right now the client has a clearpass on VMWARE and he is using a 500GB HD
I bealive there is a tool to expand of the actual virtual hard drive on VMWARE but if i use that do i need to do something on the Clearpass so he detects that he has a bigger Hard drive?
Or i need to add a NEW HD of 1 TB? thats the part im confused...
Can someone enlight me on the part of VMWare wht must be done step by step?
Cheers
Carlos
Alternetworks Corp
Moderator
Re: Clearpass upgrade 6.4 to 6.6 In virtual appliance
You must add a new drive to the VM and as part of the upgrade, CPPM will be installed on the new disk and corresponding DB + data is copied over.
We do not support in CPPM expanding the underlying disk.
Best Regards
-d
ClearPass Product Manager
