Clearpass - wired sponsored access
Hi all,
I want to make following situation with Clearpass:
When connecting wired, the user is redirected to a portal where he could enter his sponsor mailaddress (AD driven) and his own information. The sponsor gets an e-mail where he could select in which role the user has to come coresponding a VLAN which Clearpass pushes.
Could someone help me with this?
Kind regards,
Thomas
Re: Clearpass - wired sponsored access
Did you look at the ClearPass Solution Guide for Wired Policy Enforcement? It doesn't specifically cover sponsor, but it's as easy as enabling sponsor in the guest workflow.
Tim Cappalli | Aruba Security
Thanks for the reply! No I didn't check it. Could i find it on support.arubenetworks.com?
Kind regards,
