Contributor I
Clearpass with 7.4
Hi guys, I just upgraded my WLC to 7.4 and now im having issues with URL- Redirect .... I haven't changed anything but upgraded my controller, now whenever i connect to the SSID it is allowing me straight to the internet?? If i look in clearpsas i see that it is getitng the correct enforcement profile that should be sending back the URL-Direct any other things i should try? FYI, this is for onboard not guest.. and i have the controller set for  Conditional Web Redirect..
[Mod note: edited subject line for clarity]
Re: c;earpass with 7.4
Can you take a look at the logs within Cisco?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
I believe that there are some ACL changes between different code versions of the WLC so you might have to go in and recreate them in the controller.
Thank You,
Troy
Contributor I
thanks for the quick response guys, Actually after upgrading i was looking at my WLAN and "Allow AAA override" was now unchecked.
This seemed to do the trick if anyone comes accross this same issue.
