Clearpass with Office 365 and azure AD logins
Has anyone set up this?
I would like a a how to or something that can help me to set up this...
Anyone? on microsoft side and clearpass  side.
Cheers
Carlos
Alternetworks Corp
Re: Clearpass with Office 365 and azure AD logins
Hi Carlos,
What are you trying to do exactly? Can you explain in a bit more details?
Cheers
James
Cheers
James
We are trying to configure 2 SSIDS
We want that in 1 ssid they use their office 365 credentials with name@mycompany11111.com and his password of his email account
We also one a second SSID that they use their office 365 credentials like name@mycompany2222.com and the password  of his email account
As you see those are 2 different domains
We do not want that users on mycompany2222.com domain log in on the ssid 1 and log with their credentails in there
I understand it was possible with Microsoft Azure AD social media login.
Cheers
Carlos
Alternetworks Corp
Carlos - Does the customer have an Azure AD admin that can assist with the
API account creation?
Tim Cappalli | Aruba Security
We use office 365 in our office
And we got someoen that got access to the api creation account
If you tell use how to do it we do it.
Alternetworks Corp
Tim i found out this
This is how you do it? at least to get teh client id and pass
https://auth0.com/docs/connections/enterprise/azure-active-directory
Alternetworks Corp
At quick glance, that looks correct. Some of the screenshots may look different as the new Azure dashboard/UI is live now.
I tried that as they gave me permission to our account
But when im testing the captive portal
I get redirected to a microsoft page which i get like this
microsoft.PNGi dont get the box to put my user and password....
Alternetworks Corp
Hey Tim
I was able to make it work.
I was thinkign that if i didnt see the box, maybe the box had another url,so i just used mozilla debugging tool to see where he was going, and i just added the new urls on the controller pef rules.
Now its working
Thanks for your support like always Tim
Cheers
Carlos
Alternetworks Corp
