Contributor II
CoA with HP WLAN
Hi all,
ClearPass integration with HP WLAN guide suggests, that Guest users are initially placed in "VLAN 50", and after successful CP authentication CoA is initiated. This as result disconnects user device from WLAN, and when device reconnects it is now placed in "authenticated VLAN".
All of this is quite clear, and my question is do you know how long will "CoA initiation -> disconnection -> re-authentication" take? Thanks in advance.
Alan Ford
Kind regards,
AlanFord
