Contributor I
Concurrent connections limit issue
hi,
we have issue with limiting clinet device number,
controller config:
RFC--> cppm ip
accounting -->cppm assigned
cppm configuration:
insight enabled
service:
mac cashing service:
authentication source insight. endpoint repos,
auth endpoint repos   unique device count grteater than 1 deny access profile
***issue is that unieuq device count doesnt increment when same username connected with 2 different device,
do i need to sql command in side the insght?
Trusted Contributor I
Re: Concurrent connections limit issue
did you build the services yourself or via template? can you share how they look?
