Occasional Contributor I
Configure MGMT \ DATA port via iLO integrated remote console
Is anyone know, either we can configure mgmt | data port via iLO remote console for clearpass25k appliance?
Re: Configure MGMT \ DATA port via iLO integrated remote console
If you have access to the CLI of ClearPass, you can configure MGMT and Data ports as well as hostname, DNS, timezone, etc.
These items are configured during the initial setup, but can be reconfigured afterward as long as you have CLI access to the device.
I have used an iLo to accomplish this in the past.
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
Hi Michael,
Thanks for your response.
Yeah i'm aware of the intial setup if we have an access via console to the appliane or access to the CPPM.
unfortunately, I have access only to the iLO console connection , now we need to find a way to configure both mgmt|data port via iLO console.
Good to know, you used iLO to configure the MGMT | DATA port
and is it the same cmd you ran and it worked ?
config ip mgmt x.x.x.x netmask 255.x.x.x. gateway x.x.x.x
config ip data x.x.x.x netmask 255.x.x.x. gateway x.x.x.x
This is my first time using iLO to config these ports . so trying to make sure before i proceed on this.
Thanks once again for your response.
Yes, the command is as follows:
configure ip <mgmt|data> <ipaddress> netmask <netmask address> gateway <gateway address>
(Borrowed from cappalli) :-)
Michael Haring
Finally, i can confirm that we were able to configure the MGMT port from ILO console.
Magesh
