Super Contributor I
Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
Hi Team:
I can configure ClearPass Guest with an OmniSwitch Alcatel Lucent. I configured web login and have message error:
My configured ClearPass is following with an service Web Authentication:
What would it could be the error?
Re: Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
That usually means the MAC address is not being sent in the URL redirect. Can you confirm that?
Tim Cappalli | Aruba Security
What do you use in the Access Tracker ?
Do you have a webauth service?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Super Contributor I
I send url redirect for authentication mac. The portal login authenticate with me Guest Repository (Service -- Authentication -- Guest Repository)
Example: https://www.youtube.com/watch?v=gVUUE59ptPI
Try adding the following to the end of the URL in your enforcement profile:
?%{Connection:Client-Mac-Address}
Super Contributor I
If I tried it also with no success. I have to consider something in the configuration of the Switch?
Try creating a webauth service
Thank you
Victor Fabian
Super Contributor I
Hi Team:
The solutions is the following.
Thanks you
Thank you for the follow up...
Thank You,
Troy
