Configuring TACACS+ on ClearPass for Cisco switches
This thread has been viewed 107 times
  • 1.  Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 05, 2014 09:30 PM
    I would like to use ClearPass to configure TACACS+ for Cisco switch authentication to Windows Active Directory.
    Does anyone have any advice or documentation on how to do this?
  • 2.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 05, 2014 09:42 PM
    You can use the start here and at the top there is a link to use the 1. To generate sample Services for common use cases, go here. this has sample TACACS.
    Im currently working on one for ASE and will post an update when done.
    https://ase.arubanetworks.com
  • 3.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 05, 2014 10:09 PM
    I can't find the TACACS article.
    Please update once you have completed it :-)
  • 4.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 08, 2014 12:12 AM
    The solution is now posted on ASE.
    https://ase.arubanetworks.com/solutions/id/80
  • 5.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 08, 2014 10:05 PM
    Awesome, that looks great.
    Quick question: If TACACS is unavailable, will the "Accounting" part of the configuration still allow a locally configured user account to logon and gain access to priviledged mode and config mode?
  • 6.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 08, 2014 11:04 PM
    Yes it will fail through. If the server is unavailable then it will auth locally. You will just need to setup a local account on the switch also.
  • 7.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 16, 2014 05:59 PM
    I've tried exactly the same config in a test scenario, and it doesn't work.
    I get this:
    Authorization Requests Messages
     Command - -
    Error Message: No enforcement profiles matched to perform command authorization
    Error Group: Tacacs authorization
     Alerts for this Request:
    Tacacs server Tacacs service=shell not enabled
  • 8.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 17, 2014 04:15 AM
    What model of switch and iOS?
    Sounds like you don't have the proper settings in the enforcement.
    Take a look at the screen shots in the hoe to and see if your enforcement matches. I've seen different variables used in different models and even iOS version. Unfortunately Cisco was not consistent on the return attribute that are needed.
  • 9.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 17, 2014 04:50 AM
    3750 ... 12.2 IOS and 15 (I'm testing on 15).
  • 10.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 22, 2014 08:54 PM
    As a matter of interest, what do these lines of the Cisco config actually mean?
    aaa authorization commands 0 default group tacacs+ none
    aaa authorization commands 1 default group tacacs+ if-authenticated
    aaa authorization commands 15 default group tacacs+ if-authenticated
  • 11.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Oct 23, 2014 12:59 AM
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Accounting-with-Cisco-switch/td-p/173028
    Switch(config)# tacacs-server host 172.16.16.200 key aruba123 (Note that in some versions of IOS the key must be entered on a separate line of config: tacacs-server key aruba123)
    Next we setup AAA authentication:
    Switch(config)# aaa authentication default group tacacs+ local
    Switch(config)# aaa authentication enable default group tacacs+ enable
    This tells the switch that, for login attempts, to first look at TACACS, if that is unreachable, use the local database. When a user types "enable" to gain privileged mode access to first check TACACS and if that is unreachable, use the locally stored enable password or secret.
    Now we setup AAA authorization for commands:
    Switch(config)# aaa authorization commands 0 default group tacacs+ none
    Switch(config)# aaa authorization commands 1 default group tacacs+ none
    Switch(config)# aaa authorization commands 15 default group tacacs+ none
    This sends all commands entered at the privilege level 0, 1 and 15 to the configured TACACS server(CPPM) for authorization and failing that, it disallows the command.
    Levels 0, 1 and 15 map to the following:
    • level 0—Includes the disable, enable, exit, help, and logout commands
    • level 1—Includes all user-level commands at the router> prompt
    • level 15—Includes all enable-level commands at the router# prompt
    Lastly, if you want to audit Cisco config commands:
    Switch(config)# aaa authorization config-commands
    This instructs the switch to run all config level commands through tacacs for authorization.
    Be a good little Cisco admin:
    Switch(config)# exit
    Switch# write mem
  • 12.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Aug 20, 2015 02:26 AM
    I followed the ASE and imported the XML file into CPPM.
    I'm running into an issue where I'm able to Authenticate but authorization fails.
    The 3750 switch comes back with "tacacs authorization failed"
    I'm attaching a couple of screenshot of the CPPM logs.
    What am I missing here?
  • 13.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Aug 20, 2015 02:35 AM
    looks like an earlier user posted a similar problem
    I went and did a debug on the switch.
    Mar 30 07:06:31.213: AAA/BIND(00000041): Bind i/f
    Mar 30 07:06:32.773: AAA/AUTHOR (0x41): Pick method list 'default'
    Mar 30 07:06:32.782: AAA/AUTHOR/EXEC(00000041): Authorization FAILED
    labtest_sw_3750x#
    I get this...
  • 14.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Aug 20, 2015 03:26 AM
    per your screen shot you are returning a aruba not cisco response
  • 15.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Aug 20, 2015 03:28 AM
    Also it looks like you are hitting the wrong service
  • 16.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Aug 20, 2015 10:55 AM
    I did see that and it was confusing me as to where that might have been misconfigured given that I imported the generated XML file from the ASE page.
    What is an interesting behavior that I just noticed this morning is that I am passing Authentication with no need for Authorization when I log in via console (is this normal)?
    See the attached screenshot for the successful authentication via console to the Cisco switch
    attached here
  • 17.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Aug 20, 2015 11:02 AM
    Troy,
    Here are the screenshots of the relevant sections in CPPM.  How do I troubleshoot or make modifications to return a Cisco response as oppose to an Aruba response (I don't think this is a switch configuration issue)
    Also I checked all the sections and I can't find where I can modify to change the service (where you mentioned I am hitting the wrong service)
  • 18.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Aug 20, 2015 11:45 AM
    You need either move the service above the aruba device auth or make the aruba auth more restrictive.
  • 19.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Aug 20, 2015 12:47 PM
    Troy,
    Thank you for taking the time to help me, I do appreciate it as I am brand new to Clearpass and I'm evaluating the product for our internal use.
    I think I understand what you are saying, I am stuck however at the particular section of the configuration in CPPM where I can move the service above the Aruba device Auth.  What is also throwing me off is that it works if I console into the switch (which doesn't include authorization based upon the logs) but with SSH, authorization is failing.
    If you look at the screenshot that I attached, I can't edit the "Aruba device access policy" because it is a default entry (to make it more restrictive) and I am not sure how I can move up the "Cisco Wired" policy above the Aruba device access policy.
  • 20.  RE: Configuring TACACS+ on ClearPass for Cisco switches
    Posted Aug 20, 2015 08:39 PM
    So I fixed the issue.  I was able to re-order the services.
    I'm now trying to tackle AAA command authorization.  I have one profile where I am allowing Privilege level 15 with all the commands available.
    I now want create a "NOC" user with only certain commands available to this user.  I created a 2nd enforcement profile.
    I'm attaching the screenshot.  I created an enforcement profile called "NOC_Profile"
    Type: TACACS
    Services:
    Privilege Level: 1
    Selected Services: 1. Shell
    Service Attributes
    Type: Shell
    Value = 15
    (so that when user NOC logs-in, the user is placed directly into "enable" mode)
    Commands:
    Command: Show version
    Arguments: show version
    permit action: Permit
    Unmatched Arguments: Permit
    Am I configuring the Authorization commands wrong?
