Frequent Contributor I
Configuring alias. Need help
I am configuring rules as well as alias for guest access
I want to know whether i have to enable the "invert" option in the alias else not ?
Here is the snapshot
Frequent Contributor II
Re: Configuring alias. Need help
The "invert" makes the rule opposite.
So for example if you define host 192.168.1.1 as a destination. If you enable "invert" the rule will hit EVERY OTHER ip than the one in the rule.
Same with networks. If you define 192.168.1.0 as a network and enable invert, the rule will hit EVERY OTHER network than the one in the rule.
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
[ Edited ]
What do you mean by the rule will hit EVERY OTHER ip than the one in the rule ?
i have define the 2 networks
172.16.0.0
192.168.0.0 and enable the invert option.
Now please again tell me what do you mean by above statement ?
You mean after enabling the invert the rule will not be implemented on the above networks ?
Yes, the invert rule will not be implementet in the above networks, but in all other networks than the ones defined.
Maybe it will be easier to understand if you look at the definition of the word "invert":
in·vert
verb (used with object)
1. to turn upside down.
2. to reverse in position, order, direction, or relationship.
3. to turn or change to the opposite or contrary, as in nature,bearing, or effect: to invert a process.
4. to turn inward or back upon itself.
5. to turn inside out.
-ACMX #352-
Thankyou soo much sir for your kind cooperation...
Problem resolved. :)
