Contributor I
Connecting Chromebooks to wireless
We just received 3 Samsung Chrombooks and they will not get on our network.
According to the Chromebook help system Help :
Your Chromebook can connect to the following types of networks:
  • Standards: 802.11 a/b/g/n
  • Security: WEP, WPA-PSK, WPA-Enterprise
Am I really going to have to create a new SSID just because these things can't handle WPA2?
Also, what is WPA-Enterprise? I don't see that option in my list of possible encryptions, is it something that Aruba doesn't support?
Mark
Re: Connecting Chromebooks to wireless
I have connected many Samsung Chromebooks to WPA2-Enterprise networks.
Can you give us a little more detail about it not connecting?
What message are you getting? Are you seeing anything on the controller or authentication server?
Tim Cappalli | Aruba Security
You need to do an update that will allow you to use those type of authentication , connect the device to the wired and then try again
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hi Mark, we are able to connect our chromebook to both wpa2 and wpa-enterprise (802.1x)
Contributor I
interesting. The official chromebook help says it will not connect to wpa2. However we have been able to get it to connect to WPA-PSK and WPA2-PSK. Of course all of our networks are WPA2-Enterprise
What happens if i change the SSID? does everyone connected get dropped and have to reconnect?
Mark
Frequent Contributor II
We have our chromebooks connected to wpa2 enterprise. Only thing I wish clear pass would decide if they are computers or Linux embedded. It's really hard to profile.
